6.0 intake manifold on early 5.7 LS1
Old 05-19-2010, 05:33 PM
ls1-ez's Avatar
Default 6.0 intake manifold on early 5.7 LS1
Hi - wondering if a 6.0L intake manifold system will fit a 98 5.7l LS1.
Thanks in advance.
Great forum here.
Old 05-19-2010, 06:22 PM
02*C5's Avatar
What type of manifold an LS2? if so there will be no issue but...BUT if its not ported forget it you will not gain anything from a LS6 to LS2 swap even though its a 90MM but the flow in stock form is pretty shitty. Also you will need to get different injector "O" rings can't remember the size right off the top of my head if your using any LS1 type of injector.
Old 05-19-2010, 07:53 PM
rich5368's Avatar
If it's a truck manni it won't fit under your hood.
Quick Reply: 6.0 intake manifold on early 5.7 LS1
