Why/where is my coolant disappearing???
Old 05-21-2010, 12:42 PM
C Murda's Avatar
Default Why/where is my coolant disappearing???
Ok so I just put this motor in a new chassis I bled the air out of the system rad cap off heat on and run till no bubbles... Now I drive around for a day and get a constant coolant smell when I come to a stop then when I get home I'm almost down a gallon!!!! Of coolant and there are no signs of leaking anywhere????
Old 05-21-2010, 01:24 PM
98RedBird's Avatar
You check your oil? See if there's any mixing in there? You smell it coming out of the exhaust. First impression sounds like a head gasket possibly.
Old 05-21-2010, 02:27 PM
rich5368's Avatar
My yukon did this and it was the water pump gaskets. Apparently they tend to go bad. Never left a puddle on the ground but would leak and burn off the block when running so it always smelled of burning coolant.
Old 05-21-2010, 02:48 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Check the timing cover to see if anything is dripping from the water pump weep hole; as already stated, check the engine oil level; if you are using a factory style power steering pump cooler, check the power steering pump reservoir; with the hood up, check to see if there is a splatter line from coolant being slung off the belt; check your overflow tank for cracks. I guarantee you it is going somewhere, which means it is coming from somewhere.
Old 05-21-2010, 05:35 PM
C Murda's Avatar
well started taking things apart only to find that my nice semi new griffin radiator is actually damaged!!! one of the cooling tubes actually got pinched and theres fluid all around the fins so i take it its been leaking when the car gets hot and the fans help dispearse any evidence and that would explain the smell when i come to a stop... so add a new griffin radiator to the list of replacement parts WTF...
Old 05-21-2010, 09:38 PM
MeentSS02's Avatar
That sucks...how did it get damaged?
