Pic of JPR lifter tool in use....
Old 01-12-2004, 10:44 AM
haole_boySS's Avatar
Default Pic of JPR lifter tool in use....
Does anyone have a pic of someone using the JPR lifter holding tool? I was wondering where exactly the tool was placed to hold all the lifters.
Thanks,
Andy
Old 01-12-2004, 11:13 AM
BenKey's Avatar
Don't have a pic, but have used a couple of times. Believe there is a pic on the LS1howto site, if it's back up. Basically, once your timing cover is off, you'll see two holes, one on each side of the cam. That's where the rods will slide in. The rods are lablelled for left and right. It will only go in one way (angle).
Old 01-12-2004, 11:30 AM
jmX
jmX's Avatar
There's a pic in the cam install writeup here:
http://www.ls1howto.com/index.php?article=23
(yes, the site is back up now)
Old 01-12-2004, 02:02 PM
Thanks JMX, you are the man when it comes to LS1 Install write ups.
Quick Reply: Pic of JPR lifter tool in use....
