Will Heads work?
Will Heads work?
Came across a deal on a set of TSP 5.3 heads with 58cc chambers. I have a stock bottom end and my cam is .602 .610, 236 242 on a 114+4 lsa. The heads 2.02 x 1.57 valves. Would I have to notch my pistons to make these heads work?
LS1Tech Premium Sponsor
You'll have to flycut for that one! With those heads milled to 58cc's, the largest cam (roughly, you would have to check it) that will be likely to fit is MAYBE our 228R.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks guys! I really want to run a set of these heads, but I don't want to notch my pistons because I do run a little Nitrous. The unmilled ones from TSP will work though so I need to get up a little more cash.
