need cam bearing part number ASAP!!!!!
I need to order a new set of cam bearings for my rebuild. I looked on my F-body parts CD and came up with:
Bearing #1 and #5 = 12453167
Bearing #2 and #4 = 12453168
Bearing #3 = 12453169
but when I go to put the part numbers in at GM Parts direct, each part number says "ALL" and it lists at $71.60? Whats going on?
damn....just got off the phone with the dealership.....
those things really are $71.60 EACH!!!!!!!!!!!!!!!!!!!
I'm not going to be able to sit down for a month my *** hurts so bad
F*ing LS1
where else do I look?
F*ing LS1
The factory bearings are sold individually at a very high price.
Clevite sells them for under 30$ a box under part number SH 1814S
Sealed power/ Federal mogul sells them under part number 1888M.
If your block was produced after aug. 2003 it needs a different bearing that is not serviced yet.
Kurt
Originally Posted by 427
If you are looking for gen 3 bearings there is 3 different sizes in each set.
Kurt
Kurt
If I can get one of those numbers (SH 1814S or 1888M), the box will have all 5 bearings right?
Thats what I need (bearings for my 01 block). I called Napa but neither of those numbers worked in their system. Where did you get yours?
I buy direct from Clevite and Federal mogul
Kurt
