different cam thread
I'm not asking which cam to get i am asking for all that have had any/many cammed ls1's how big of a cam would you go if you had a dd. My car is a DD, m6 but i wanna push my car to the limit but still be able to drive it, so with that being said whats you'alls opinion on the specs of a cam that i should get thats going to give me the most power(under the curve im guessing) but still be able to be daily driven all day. what specs/lsa/duration/lift would you'all go with thx in advance for posting. if it matters car will mostly be street raced 90% and tracked the other 10%.
LS1TECH & Trucks Sponsor
You might take a look at our torquer v.3 camshaft(231/234 .643"/.598" 111lsa). It is a mid duration camshaft with a broad powerband due to the lobes used on it. It has an aggressive idle due to the 111 lsa but this also brings the power band down. With a good tune and the right valvetrain components this cam can be daily driven easily.
I would go with something like john said; 23x-23x... no lower than that because you will regret.
I'll add that the torquer 2 have less lift, which is going to be easier on valvetrain for your DD. its in the 232/234 595/598 lift range, so you can run a single srping kit too.
and how broad are we talking here due to the lobes used on it?
and by lobes u mean 231/234 correct?
and what would you reccommend as right/best valvetrain components for that cam? (also best valvetrain components for any cam or does the valve comp's depend on which cam picked right?) 1st Thx to John at TSP
[QUOTE=orangeapeel;13387099]I'm a bad person to ask with my 2 last cam choices, but, the EPS lobed cams are fairly small and deliver quite a punch. Let me find the thread.[/QUOTE
Was thinking bout this route a lot also. Whats (LSR) lobes exactly 4th Thx goes itsslow98
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There are several different lobe styles you can have cams ground on for these motors. For example:
XE - Easy on the valvetrain. Don't see nearly any of these anymore.
XE-R - More aggressive XE lobe.
LSR - A newer more improved form of Comp lobes
LSK
EPS
To name a few. Most of the time they are just proprietary to a company or grinder. Like XE, XE-R, and LSR for CompCams.
LSK
EPS
LSK
EPS
LSK
EPS
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There are lots of lobe profiles out there. Those are just some of the more popular/common ones with our cars. I still think EPS is onto something with their killer well thought out cams though.
You are going to want to replace springs and pushrods at a minimum for sure. Depending on the cam will determine whether or not you will need to run a single or double spring. Double springs seems to be more popular with the crowds today. Lots of cams with mild duration and high lift.
Werd!!!
ya i know i'll need some chromoly pushrods, beehive/single/dual springs and all that good stuff depending on cam. But If you could go hindsight 20/20 what cam specs would you go with as my original thread stated?
And you say this b/c?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, the whole bigger is better isnt always the case...as you saw with that thread I linked above. I would get something that is going to be a tasteful compliment. My cam knowledge is miniscule compared to someone like Geoff at EPS. I could think up a grind, no problem, but I think you want something that has some planning and backbone structure to it. Just because you are able to drive it on the street doesnt mean its going to do you any good. The T-Rex's and the Magicsticks are great for their purposes, but its definitely not what most would consider to be street friendly though. I would look for a low to mid 230's cam with 111-112 LSA on the avg. Lift is all relative to what the cam is going to be used for mainly. It is not a factor in overlap, and you really don't want a bunch of positive overlap if you plan on DD'ing this thing. 16° is about as much as I can put up with personally. There are high .600's and mid .500's accomplishing the same goals. Just make sure you don't have a cam that is going to require you to push the bottom end to its demise.
