tsp torquer v2 cam question?
Im buying one of those package deals (heads/cams) from tsp and i want to get it with the v2 cam. If yall could tell me the best things to get with the v2 cam and show me some rwhp results. Thanks bros!
First I'm changing tuners. Then if my performance and numbers are still in the same situation, I'm changing cams. I couldn't tell you which one it will be yet, but I have a feeling it will be the cam (changing from the Tv2 i mean).
LS1Tech Premium Sponsor
If you're thinking of ordering your heads/cam soon, check out our Memorial Day sale! Free shipping on that head order, online or on the phone, through Tuesday morning! More details in the sponsor's sale section!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
^seabrook eh?
the tv2 is a good cam. and it can be DD'd. however you will see a drop in mileage. i am a fan of the 224r and the 228r. either one is great for driving every day. or you may consider something like a 228/230 custom cam.
and if i were you i'de plan on doing heads sometime in the future. i was very happy with the gains i got from just stock 799 heads. i can't wait to p&p them and go to a slightly larger cam.
Yeah been in seabrook for 12 years now.
Iv looked at about a thousand camaros and firebirds b4 i bought my z28. And all the ones i looked at with cams seemed slower and just didnt run right to me. Iv had old chevelles, trans ams, and vettes cammed and idk if its just that the ls1s are touchy or something. thats why i went for a all stock clean one.
any advice(especially the guys from tsp) if i go with the cam and heads plus bolt ons, is there any other stuff i should get to support it all that i should look into getting. I know i need to tune it, but any advice in not letting my car end up slower than when i started.
cam will require:
a good timing set. i have a ls2 single roller.
push rods. comp magnums will do.
valve springs and retainers. i like my patriot duals.
i went ahead and did a melling oil pump while i was in there.
good supporting mods:
LT's and exhaust are a must.
poly or solid motor mounts. I SHOULD HAVE DONE THIS FML!!!
lid/filter.
at least an ls6 intake. if you can find one a FAST 92/92 always helps.
if you plan on making more than 400 rwhp i would do at least 30 lb injectors.
obviously you will need a dyno tune.
a good clutch to hold the new power.
tires are always to be considered.
and as i am finding out a body mount torque is a great mod for 400+ rwhp. i need one bad
if i missed anything chime in.
