Stupid question about idle with MS3
Old 05-28-2010, 06:28 PM
skeeters65's Avatar
Default Stupid question about idle with MS3
I have a MS3 in my car. When I start the car when the engine is cold the car has a real nice raspy choppy idle. After it warms up it smooths out and doesnt sound nearly as good..
Is this normal??
Thanks
Old 05-28-2010, 06:31 PM
lvbroham1's Avatar
what lsa?
Old 05-28-2010, 07:21 PM
09camaro383's Avatar
Is normal but your lsa has something to do with it 114 smoother idle and 112 is standard so what is your lsa?
Old 05-28-2010, 09:11 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Forget LSA. What is your idle set at?
Old 05-28-2010, 10:42 PM
2000Hawk's Avatar
I have my MS3 on a 113 LSA, and it idles around 850-900 rpms I believe. Holds idle just fine, and has a very nice lope to it. Sure it doesn't sound like something John Force drives, but its enough for others to know its not stock.
-Joel
Old 05-29-2010, 12:08 AM
00cls1camaross's Avatar
Is there a problem if you set the idle of an MS3 at say 700?
It chops harder on a lower idle right?
Will it die often, and if it does, why does the engine die?
Old 05-29-2010, 12:21 AM
skeeters65's Avatar
It is a 112 LSA..
It idles right around 900rpm.(if i remember correctly)
Car never stalls out but when it is hot and is started it hunts for a smooth idle. Takes about 10-15 seconds to smooth out. Think it might be getting too much fuel at start up..
Old 05-29-2010, 08:03 AM
twitchtwice's Avatar
mine actually chops/lopes harder once its warmed up since the idle is lower at operating temp.
Old 05-29-2010, 09:07 AM
Paint_It_Black's Avatar
Engines die at idle because they choke themselves out. Too much exhaust gas gets into the intake from the overlap at low idle. That's what creates your "chop" as most put it. The engine is choking on itself.
Old 05-29-2010, 01:21 PM
Super Speed's Avatar
It's normal for an engine to idle rougher on cold starts, mine does it... Mine also chops harder with the AC on!
Old 05-29-2010, 02:46 PM
any issues with having a lower idle, I know that motor is chocking itself but can it hurt the engine setting the idle lower?
Old 05-29-2010, 09:43 PM
LaBLKv6Z's Avatar
If the idle is set to low, the engine may kill when there is a load on the front of the engine, like turning the a/c on or turning the steering wheel. Oil pressure may be alittle lower but shouldn't hurt the engine.
Old 05-29-2010, 09:57 PM
Pro_built7's Avatar
Mine hunts for idle on warm/hot start also with the ms3, stabilizes in about 5 seconds (or so).
also lopes awesome, idle is set at 850.
I love the sound, it's freaking awesome- 112 lsa
Old 05-30-2010, 11:37 AM
Do you have any idle clips of 850?
anyone try 800?
If you have the TSP shimmed pump oil pressure should be fine right?
Old 06-01-2010, 02:28 PM
skeeters65's Avatar
Just looked at my Tach and it is reading almost 1100rpm..
Is that too high??
Thanks
Old 06-01-2010, 02:47 PM
TooLateVTEC's Avatar
That sounds too high, should be around 900 or so with a cam like that.
It either has a vacuum leak or something is wrong in the tune.
Old 06-01-2010, 04:33 PM
skeeters65's Avatar
It is an Autometer Tach. It may be off a bit but the needle is a hair over 1k..
What would be the best way to track down a vaccum leak??
Thanks
Old 06-01-2010, 04:59 PM
Easiest way is to spray brake cleaner around possible problem areas and see if the idle goes up. If it does theres the leak.
Good spots to try are where the heads and intake touch, between the TB and intake manifold, vacuum lines and connections, etc.
Old 06-01-2010, 05:03 PM
skeeters65's Avatar
The brake cleaner wont hurt anything in or around the engine bay??
Thanks
Old 06-01-2010, 05:11 PM
Brake cleaner evaporates fairly quickly so it shouldnt hurt anything, might leave stuff cleaner though.
You could try WD 40 but ive never used that so im not sure if its flammable enough to work.
