any way to CC a head at home?
Old 05-29-2010, 07:49 PM
yoshgixxer's Avatar
Default any way to CC a head at home?
i bought a used set of 317 truck heads,and they have been ported and had machine work done to them..the guy i bought em from didnt know the CC of the head..is there any way i can check the CC with some at home items??
Old 05-29-2010, 08:34 PM
novaflash2002's Avatar
get a piece of plexie glass drill a small hole in it. go to the cooking untinsle isle of wal-mart and get a baster the measures in cc's. put a spark plug in the head, alittle grease around the chamber and fill away.
Old 05-29-2010, 09:14 PM
yoshgixxer's Avatar
exactly what i was thinking! but what should i use for the liquid?? water? or good old vegetable oil? haha
Old 05-29-2010, 09:17 PM
water, gas, oil what ever you like
Old 05-30-2010, 10:01 AM
chrs1313's Avatar
I would use a solvent not water...
Old 05-30-2010, 11:56 AM
monte383sbc's Avatar
i have used water cut with rubbing alcohol 50/50 and a few drops of food coloring that worked for me fine
Old 05-30-2010, 11:58 AM
UGotBeaT's Avatar
just use rubbing alcohol with nothin mixed in it...works fine.
Old 05-30-2010, 02:18 PM
yoshgixxer's Avatar
I used rubbing alchahol.. What a simple job that was.. I ended up with 73cc which makes sense since there is some work done in the bowle area.. Probably enough to make up for the 2 extra CC... That's ver good news cuz the guy I bought the heads from didn't know if they where ever decked
