Question about 5.7 versus 5.3 heads....
I have a few questions about 5.7s -vs- 5.3s and I'm too lazy to search. Both flow the same, the only difference is compression, correct? For example, a 5.7 head ported and milled .030 should produce roughly the same power as 5.3s unmilled but ported identically, correct? The advantage that 5.3s have over 5.7s is that a 5.7 has to be milled to obtain the same compression that an unmilled 5.3 head does, right?
Thanks, Shawn
Thanks, Shawn
Originally Posted by LowETz
stock vs. stock
Are/were your heads 5.3s or 5.7s? The reason I'm asking is I'm curious why everyone is leaning towards the 5.3 heads so much, you rarely ever see 5.7s being used anymore, and I was under the impression that both flowed comparibly, the only (main) difference was the added compression of the 5.3.
I know that the chamber is smaller. What about flow and power? Is the only difference the chamber size (compression)? Will a 5.7 head that is milled enough that the chambers are the same size flow the same/make the same power as the 5.3? Or are there actual flow/port differences?
OK:
Head A: 5.7 head, (milled to where the chamber size and compression is equal to that of the unmilled 5.3 head), 2.02 & 1.60 valves, CNC ported with the same program as the 5.3 head.
Head B: 5.3 head (unmilled, assume same chamber size and compression as 5.7 head milled .030), 2.02 & 1.60 valves, CNC ported with the same program as the 5.7 head.
Both heads will (theoretically) flow the same and produce the same power, right? (Assuming compression and chamber size is the same.)
Ok, take a ported 5.7 and a ported 5.3 from the same company, the same size valves, springs, CNC program (for consistency, we'll use TEA, PP, or another "CNC" porter). Will the 5.7 flow the same and produce the same power as the 5.3 head, if the 5.7 is milled to make up for the difference in compression that the 5.3 has?
FWIW....Brian is getting as good or better #'s from the stock valve as the aftermarket valve, and the load test results from the stock valve was insane. I had no idea they were that strong. Don't quote me, but I believe Brian will also confirm that for N/A combo's, the stock valve will hold up just as well as the Ferrea, the only benifit being the Ferrea is lighter.
