camshaft change
Old 06-02-2010, 10:38 PM
dec010974's Avatar
Default camshaft change
hello ls1 tech fam. im performing a cam swap in a '02, lq4 and read that once the bolt used to hold the balancer in place, on the crankshaft, was removed, it cant be reused. T or F? also what size pushed rods are needed for the hot cam? the springs im gonna use r the ls3 springs. i got them for the low low. thanks.
Old 06-03-2010, 09:28 AM
dec010974's Avatar
Default answers
hello. to all. i hope someone can give me some insight on this cranshaft bolt. thanks again.
Old 06-03-2010, 10:24 AM
SOMbitch's Avatar
Factory bolt is torque to yield and should NOT be used again. ARP bolt can be reused.
Save the factory bolt though to do your initial 240 ft. lb torque sequence then put on your new bolt and retorque to 70 ft. lbs and then 135*-140* past 70 ft. lbs if using a gm TTY bolt. I don't recommend using your old bolt to push the pulley on the crank snout though as you risk stripping the crank threads.
You can make a tool out of threaded rod a few washers and a couple bolts from a hardare store to push the pulley on for $6-$8 if you wanna be safe.>>>>>>https://ls1tech.com/forums/tools-fab...tall-tool.html
Old 06-03-2010, 12:36 PM
Russ K's Avatar
The proper torque is 37 ft lbs, not 70.
Russ Kemp
Old 06-03-2010, 01:06 PM
SOMbitch's Avatar
Russ Kemp
^^^^^ Correct.... My head has been up my butt all day for some reason......
Old 06-04-2010, 04:28 AM
dec010974's Avatar
Default camshaft change.
can some one explain this a little better. i got lost. thanks.
