5.3L swap/no oil psi
Old 06-07-2010, 07:39 PM
70lx327's Avatar
Default 5.3L swap/no oil psi
5.3L with muscle car pan swap etc.. I double checked the oil tube pickup when installing to make sure the oring did not get pinched. checked this twice. i cheked to make sure the tube was sitting flush as well. I get the car to start and no oil pressure. Pulled the oil fill cap and no oil up to the heads. My research on the forum would indicated my pickup tube is not sealed and need to pull the engine right????
Before i go to this task what can i do to eliminate any other possibilities?
Is it possible to remove the pan with out pulling the motor out completely?
Thanks for your input.
Old 06-09-2010, 01:14 PM
Banned Scammer
434strokergt45r's Avatar
you might not have anough clearance from pick up to pay or pump or oring or barbell in the back of the block
