How to tell the difference between 4.8 & 5.3?
Old 06-08-2010, 06:18 AM
Strokinit383's Avatar
Default How to tell the difference between 4.8 & 5.3?
I went last night to pick up a 5.3 and could not figure out if it was a 4.8 or 5.3. The block was marked 4.8L/5.3L, 862 heads. The guy worked at autozone and called a coworker, who was working at the time. According to the coworker, both the 4.8 and 5.3 could have the 862 heads. Is there anyway to tell externally? He claimed it was from a '03 tahoe.
Thanks!
Old 06-08-2010, 07:14 AM
Emulsifide's Avatar
There should be a part number on the side of the block that you should be able to cross reference....at least I know there is for the aluminum LS blocks. I doubt it would be different.
Old 06-08-2010, 10:55 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Unfortunately, this is incorrect. The 4.8L and 5.3L use the same block.
OP: Does it have the pan and all on it? If not, you could cross reference the crank casting number and it will tell which it is (different stroke between the two). That'd be the quickest way to tell for sure.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: How to tell the difference between 4.8 & 5.3?
