Is this normal on a AFR head?
Old 06-08-2010, 10:51 PM
javier1730's Avatar
Default Is this normal on a AFR head?
hey guys..i finally got everything i needed to do my H/C/I swap so i decided to take a look at my AFR head which i bought i while ago and i noticed that where the rocket arms seat it seems to me like they are chipped... what do you guys think...will this be a problem? im sorry for the pics quality i had to take em with my cell phone.
Attached Thumbnails Is this normal on a AFR head?-imag0051.jpg   Is this normal on a AFR head?-imag0052.jpg   Is this normal on a AFR head?-imag0053.jpg
Old 06-08-2010, 11:12 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I take it these are used?
Old 06-08-2010, 11:15 PM
javier1730's Avatar
yeah the guy i bought them from had put less than 500 miles on them
Old 06-08-2010, 11:23 PM
OUTLAWZ RACING's Avatar
That looks bad.... I know rockers dont need alot of tq to hold them down but the material looks week like he used larger bolts.
Old 06-08-2010, 11:26 PM
javier1730's Avatar
Does it has a solution or are they shot?
Old 06-09-2010, 12:17 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Hard to tell anything from your pictures to be honest. May want to take them and get them checked out atleast.
Old 06-09-2010, 04:50 AM
vettenuts's Avatar
Send some better photo's to AFR, I'm sure they can advise you.
Old 06-09-2010, 05:01 AM
98PurpleT/A's Avatar
I'll try to take some pics of my heads tomorrow night so you can compare my new heads to yours. I don't think mine looked like that when I got them.
Old 06-09-2010, 05:59 AM
javier1730's Avatar
here is an update on the pics ..this ones came out better...and thank you guys for all the help.
Attached Thumbnails Is this normal on a AFR head?-dsc04669.jpg   Is this normal on a AFR head?-dsc04670.jpg   Is this normal on a AFR head?-dsc04671.jpg   Is this normal on a AFR head?-dsc04672.jpg   Is this normal on a AFR head?-dsc04674.jpg
Old 06-09-2010, 06:13 AM
SSdreamz's Avatar
when i bought my brand new AFRs not so long ago, mine looked the same. I called AFR and they said its normal, that the casting slag was just knocked off before the milling making it look like a chip... I thought for the money i just spent, they should look like diamonds, but owell. still on the car without a hiccup...
Old 06-09-2010, 06:24 AM
butler's Avatar
my 225's look the same. no problems.
Old 06-09-2010, 07:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just looking at the pictures, it does appear to be the "manufactured look". Tony Mamo may be able to advise as well if it would help ease your mind though. I bet he will see this thread.
Old 06-09-2010, 09:15 AM
javier1730's Avatar
well thanks alot for all the info guys...i feel better now i thought i had spend 2k on a piece of junk.. i hope tony see the threat and clarify any doubts.
Old 06-09-2010, 11:52 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
It's not an issue....
Guys....thats simply a flat pad that a rocker pedestal attaches to. It doesn't have to look pretty to work properly....it just needs to be machined flat which it obviously is and there is plenty of aluminum there to support all the rocker arms, pedestal stand, etc.
That said I would like to add that we do care about aesthetics as well and are working with the foundry to improve the tooling in that area. Look to see some improvements there in the next three to four months but rest assure its nothing but a slight cosmetic issue at this point.....nothing to worry about regarding function or proper operation of your new heads.
Hope this helps...
-Tony
Old 06-09-2010, 10:08 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Hope this helps...
-Tony
Thanks for the nail in the coffin Tony!
Old 06-11-2010, 07:17 AM
I'm late lol
I just took my AFRs out of the box and they are the same as yours
Attached Thumbnails Is this normal on a AFR head?-100_0895.jpg   Is this normal on a AFR head?-100_0896.jpg
Old 06-11-2010, 06:51 PM
Flow Wizard
Guys....
Focus on the porting work, chamber and port designs, quality of the parts and the overall execution of all the machine work.....ultimately that is what your really paying for.
I promise though before this year is out the rocker pads will look "pretty".....LOL
Old 06-11-2010, 08:12 PM
DaddySS's Avatar
Tony is right (of course), those are castings to support the rocker plates and hold the bolts - not material to the performance or reliability of the heads.
Old 06-11-2010, 08:43 PM
javier1730's Avatar
[QUOTE=Tony Mamo @ AFR;13456163]Guys....
=)[/QUOTEl
lol i think you're right, and i don't really care about the look i just had a doubt on that little detail...thanks for clearing things out....And i have another question for you Tony since those 205's have a 72cc chamber and im planning on going with an n2o set up how much would it be safe to mill to bump the comp up?
Old 06-11-2010, 08:52 PM
Flow Wizard
Actually they come standard at 66 cc's (they aren't even offered in anything larger)....just an FYI
-Tony
