i have Questions about the ASA Cam 226/236 .525/.525 110 lsa
Old 06-09-2010, 06:46 PM
Fastdriver1992's Avatar
Default i have Questions about the ASA Cam 226/236 .525/.525 110 lsa
does this cam have any piston to valve clearance issues? could i use a thicker head gasket to make it fit?
Thanks
Anthony
Old 06-09-2010, 08:23 PM
99SSAGUI's Avatar
This cam has minimal lift and is not too big so I don't think you will have an issues. Do you have aftermarket pistons or rods? how about your heads? If you have aftermarket pistons and milled heads you will have to measure since usually pistons will stick out farther out the hole than stock pistons. Good luck!
Old 06-10-2010, 02:36 AM
Paint_It_Black's Avatar
Although max lift has absofuckinglutely ZERO to do with PTV clearances, no, you will not have issues and can even run a thinner head gasket. On stock setups you aren't going to worry about most lobes on 110 ICL. Hell the T-rex fits under stock heads and that's a 242 degree lobe on a 110!
Old 06-10-2010, 02:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
^^^ There will always be someone who thinks lift is the do all/be all.
Old 06-10-2010, 06:34 AM
ok thanks alot guys i was just worried about the 237 duration, thats why i thought it would hit. i put in a 228/232 .551 lift 112 lsa crane cam in my other car and i had issues so i wanted to avoid them
Thanks
Anthony
Quick Reply: i have Questions about the ASA Cam 226/236 .525/.525 110 lsa
