How much power and rpm on stock rods
Old 06-09-2010, 08:26 PM
00ss6speeder's Avatar
Default How much power and rpm on stock rods
Thinking of putting a good set of heads and cam in my SS, its a 2000 model but I have an 02 model LS1 to go in it. How much horsepower and rpm can the stock rods in 02 motor hold up to? Could I put any nitrous to them?
Old 06-09-2010, 08:31 PM
supersick99z's Avatar
I have heard stock internals are good until about 600 and then things start to possibly go downhill. And yes of course you can throw some nitrous on it!!
Old 06-09-2010, 08:33 PM
getsum27's Avatar
theres quite a few high hp cars around here have had no problems
i think the rod bolts is more of a concern and i think its like 66-6800rpms before its an issue
i know a guy that sprayed a 200 shot on his car for years and he traded it at over 100k with still no issues
also couple guys with h/c/i cars and 125/150 shot....both are well into the 500s with no problems
Old 06-09-2010, 08:39 PM
Yeah I also know a guy with 100,000 miles heads/cam/200 shot
Old 06-09-2010, 08:46 PM
So can I just replace rod bolts or do I have to get better rods in order to fit in better rod bolts. Also, what size cam can I fit in without worrying about piston to valve clearence issues?
Old 06-09-2010, 09:04 PM
02*C5's Avatar
look art my sig completely stock bottom end 2002 ls1 through an a4
Old 06-09-2010, 09:37 PM
keep it below the 240's and you won't have to even think about PTV issues
Old 06-10-2010, 02:55 PM
02*C5's Avatar
depends on the heads and chambers because on stock ls6 64cc chamber heads an ms4 can fit with no ptv issues and if i am right its a 237/242. now u should check ptv regardless but it has been done plenty of times.
Old 06-10-2010, 04:01 PM
98z-28redcamaro's Avatar
it will handle as much power as u wanna throw at it....
Old 06-10-2010, 06:59 PM
Banned Scammer
434strokergt45r's Avatar
i would not go over 600 crank hp and dont go over 6200 rpm
Old 06-10-2010, 07:07 PM
02 BLK WS6's Avatar
134k mile untouched longblock, tsp 231/237 cam, anything under a 200 shot is small imo. I don't know how much power I'm making. Full weight runs 10.50's @ 127
