Something is fked with my oil psi
Old 06-10-2010, 01:30 PM
SS4Luck's Avatar
Default Something is fked with my oil psi
Okay, so i just noticed this, i have no idea how long its been doing it, but wheni go WOT in 1st gear i lose psi, yet as soon as im in 2nd im straight up to 80+psi. Any idea? Idle is right around 35 psi im just baffled.
any ideas?
Old 06-10-2010, 01:33 PM
1SLwLS1's Avatar
only in 1st or WOT at all? Maybe you are low on oil? I would definitely start with a mechanical gauge. Check your oil level too. I am not sure where the pickup is, but if you are low and slinging it all towards the rear, you could starve the pump.
Old 06-10-2010, 01:47 PM
SS4Luck's Avatar
yeah its only first gear... which is what makes me a little more curious about what it is...
Old 06-10-2010, 01:51 PM
1SLwLS1's Avatar
The only thing I can think of gear related would be the acceleration and slinging your oil back, but I would think that would continuously occur. Maybe in your situation you are on the brink of low oil.
Old 06-10-2010, 01:59 PM
SS4Luck's Avatar
the stick reads fine, i put an extra 1/3 of a quart in to see if that helps it. I got a mech gauge on its way, ill keep you updated
hows your MS4 with the 3.42s btw?
