Brand new ls6 crate motor, no oil pressure. Wtf is goin on?!
Old 06-13-2010, 06:27 PM
Taubr Unit's Avatar
Default Brand new ls6 crate motor, no oil pressure. Wtf is goin on?!
We just did a ls6 swap in my buddys silverado because his 5.3 lost all oil pressure. Bought a ls6 crate motor from SDPP and still the same damn thing!! Heres whats goin on.... Inital start up was ticking but new motor, no oil etc so thats normal. After about 10 seconds of idle the oil pressure drops to 0, low oil pressure light comes on an motor starts to tick real bad so we have to kill it. WTF, brand new long block doing the same thing the old 5.3! Any advise?!
Old 06-13-2010, 07:17 PM
JasonSS2000's Avatar
Did you swap the oil pickup & pan from the 5.3? Sounds like the oil pump or pickup O-ring. Before starting a new motor always leave the plugs out, coil paks unplugged, and the fulel pump fuse pulled and then crank it until you have good oil pressure. Only way to properly prime a LS based motor.
On the relation to the 5.3 loosing oil pressure it would be impossible for the new motor to have the same problem uless you have an obstruction or failure or leak between the pick-up and the pump itsself.
You did use a new oil pump, correct?
Old 06-13-2010, 07:21 PM
MYSTIC-1SC's Avatar
thats what i was thinking possibly an o-ring issue.
Old 06-13-2010, 07:35 PM
Taubr Unit's Avatar
Yes we did have to use the truck pan and pick up tube. We had both motors on stands and really took our time and made sure the o ring was good. Cleaned the pick up tube really good etc. The oil pump was installed by gm n we didnt touch it, not sayin it cant be the problem, just sayin
Old 06-13-2010, 08:55 PM
89 formula350's Avatar
does this truck have the oil cooler?
Old 06-13-2010, 09:17 PM
G Engines's Avatar
was all of the oil plugs and T-bar installed ?
Old 06-13-2010, 10:18 PM
Taubr Unit's Avatar
ok, truck does not have a oil cooler and we did not ***. the engine, its from GM. We did however make a little head room....
got a tip to pull the plugs n disconnect the coils and turn the motor over so its free reving pretty fast and that will "bleed" out the oiling system. So we did that and it got better but still not where it should be. At start up it bumps to 40psi then bleeds down to 20 and goes as low at 10 but not 0 now. Still not great but it did get better. We bought this motor from SDPP from the sale they had going on here. Was a complete long block. We did NOT remove the front or rear cover when we got it, just swapped out the oil pan n pick-up tube...the rest is gm
Old 06-13-2010, 10:23 PM
performinnorman's Avatar
Sounds like they might have left out either the front oil galley plug or the "barbell" plug in the rear oil galley above the filter.
Old 06-13-2010, 11:02 PM
i thought there was issues with oil pumps and sticking valves in them? even later ones gm had tsb on them
Old 06-13-2010, 11:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Do you know what years the service bulletin was for?
Old 06-14-2010, 04:55 PM
sorry i dont remeber i belive the early ls1's and ls6's were just random and no tsb was issued but the later '07?? ish trucks had this for sure... I used to work at a dealer and this was seen on a few trucks...
Old 06-15-2010, 01:14 PM
Would have to agree. That or the O-ring got pinched.
Quick Reply: Brand new ls6 crate motor, no oil pressure. Wtf is goin on?!
