ticking with p0327 only (NOT P0332)
Old 06-18-2010, 11:29 AM
Bad Blue WS6's Avatar
Question ticking with p0327 only (NOT P0332)
OK, i have a tick that sounds very stong under the car,,, not so much in the engine bay (all i can hear up there is the normal sewing machine sounds),, so when im sitting in my seat and open the door, bend down to look under the car,, sounds stongest there,,,, hoping its just an exhaust leak but im also getting a p0327 code,,, but not the other code. i have had both codes show up at one point about a year ago,, (p0327 and p0332) but it seems since ive erased the 0332 code it hasnt came back, but the p0327 comes back after a few start cycles,,, any suggestions? im going to get under her later today to see if i can he-man the collector to y pipe bolts up some more,, the ticking does sound like a very fast tapping or ticking,,, but im worried abou the p0327 without the other code there to jive with the whole "replace them cause of the water thing" since im only getting one code,, and not many threads on here about having just one code,, could that still be the issue even though im not getting a p0332??
Old 06-18-2010, 11:30 AM
,,, i do have a full exhaust (LT's, etc)
Old 06-21-2010, 03:01 PM
up top for any clues,, i was not able to get under there to see if anything needed to be tightened up on the exhaust..
Old 06-21-2010, 04:39 PM
Darkman's Avatar
See attached.
File Type: pdf
Old 06-21-2010, 04:50 PM
thanx, but it wont open for me,, file not found,, kinda like my brain at this point,,,, if its that "Gear Chatter" info,, i have that,,, but its greek to me.. and the only scanner stuff i have is a simple lil code reader pocket scanner.
Old 06-21-2010, 05:43 PM
Darkman's Avatar
Thumbs up
Basically the procedure is to:
1. Eliminate any actual mechanical "Knock" from the engine.
2. Assuming there is no real "knock":
a. Check the connection from the knock sensor wiring to the engine wiring harness.
b. Pull the intake and check the knock sensor harness to the sensors.
c. Check/replace the knock sensor(s).
3. If it is not any of the above it can also be connections to the PCM or the PCM itself.
Note: The PDF opens for me so I don't know what that problem could be.
Old 06-22-2010, 08:11 AM
its probably my work stuff,, firewalls and whatnot,,, thanx for the breakdown.
Old 07-14-2010, 08:17 AM
not an exhaust leak,, so i got the scope out and started listening to the engine,, i hear the tapping coming from the passenger side bank,, loudest when the scope is on the very back tube on the header,,,
the tapping goes with the rpms,, and i did miss a shift not long ago,, i will post up after i replace that pushrod.
Old 07-14-2010, 12:12 PM
Darkman's Avatar
Well I guess sometimes those pesky knock sensors throw a code just because there is a knock.
Old 07-14-2010, 12:14 PM
i know,, go figure..
Old 07-15-2010, 06:44 AM
Default Resolved
ok, pulled the PS valve cover and pulled the last two rockers,, pushrods were fine, pattern was fine,, springs looked good as well... header flange bolts were not,, the two in the middle right next to the dip stick were loose,, not crazy but one of them i bet i turned the bolt a whole rotation before it was to spec,, i didnt drive the car today, but after buttoning her back up last night she had no clicking or tapping, etc when i fired it up,, normaly it would be there right away.
Old 07-26-2010, 01:43 PM
P0327 code is back,, and so is the ticking although its not as loud,, time for other suggestions and such,, if you have any plz offer, and thanx
Old 07-26-2010, 01:58 PM
could a lifter make this kind of noise?
Old 07-26-2010, 03:54 PM
im using a lite wt oil,, 5w30 i beleive,, mobil 1,, could that cause a tick... ?
Old 07-27-2010, 10:06 AM
and today (actually once i left work yesterday) the code p0327 is gone,, could it have been pending or still floating in there since i didnt erase the code once i fixed the exhaust leak?????,, the ticking im hearing now seems to be normal sewing machine noise we all know and love ,,
Old 07-27-2010, 10:08 AM
i should also mention that my p0480 code that has been on this car since i bought in 2005 is also gone,,, (fans have always worked fine, i have replaced all 3 relays to fix, but it never went away)
Quick Reply: ticking with p0327 only (NOT P0332)
