question for those with fast intake manifold
im currently installing my 92mm fast intake, and i believe i ran into a problem but just maybe a question if anyone could answer. now when i took my stock manifold off and got to the coolant pipe, on the ls1howto website the guy used two. but i only bought one coolant pipe. now he jerry rigged his to block it off but my question is do i need 2 coolant pipes?
You can either: (a) use two coolant pipes and use heater/hose tubing to tie in with the radiator cooling system; or (b) plug the rear two with caps. The caps can be purchased from almost any GM dealer since they come stock on LS6s and LS2s.
There may be other alternatives, but these are the ones I have used.
update
alright finally got my plugs in for the rear coolant pipe. so now all i need is the oil pressure sending unit which im gonna get tomorrow at advance since they are $30 cheaper than through the gm parts department and they have it in stock with the socket wrench i need to get it off and on. ill put pictures up when finished, hopefully don't run into any issues on the install this time.
