Need advice about milled heads and PTV clearance
I'm doing a head/cam package on my car and was wondering if anyone had done anything similar and if they needed to flycut. The specifics are as follows:
98 LS1 stock bottom end
241 castings, Fully ported and milled .030 using 2.02/1.55 valves
.040 gaskets
Comp Cams XER281HR 232/234 .595/.598
I'm hoping I can get by without flycutting but suppose I will if need be, that or switch to a smaller cam.
.040 gaskets
well that sux! before I milled the heads I made a call to your shop. I told the rep what I was going to do and he told me that it would work out just fine and that you had just gotten done building something similar with milled heads and a cam in the low 23x range.
I would agree with you, but unfortunately I didn't end up buying the cam from them... I got it from a machine shop that got stuck with it when the other guy didn't pay up.
I think with a 23x duration cam and heads milled .030, you better check.
IIRC recommended PTV is .080" intake and .100" exhaust. Not 100% sure, I'd ask a reputable LSX engine builder.
Since you are using a stock short block remember that your pistons have no valve reliefs.
LS1Tech Premium Sponsor
Like always, we can make educated guesses at it, we always recommend (as John did in post #3 above) measuring to ensure you're safe. Unfortunately, there are too many variables in the combo, none of which our shop had any control of or hand in since nothing was purchased through us, to just assume clearance one way or another. Same as pushrod length, we can make an educated guess at it based on experience, but at the end of the day to do it correctly, you have to measure.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
On that note... information is readily available, but to trust just one source is a gamble. Looks like I might lose it this time
