Heads/Cam/valvespring swap break in oil choice?
Swapped heads, cam, valvesprings, etc. Been reading a bit but getting some differing opinions on the oil I should initially put in on first starting it. 5W-30 synthetic, conventional oil, break-in oil...Does it really matter? Opinions and personal use is welcome.
i just did my h/c cam swap and put in regular 5w30 to start just to clean all of the assembly lube out then i will change it back to Royal Purple 5w30 after a couple hundred miles. That just what i am doing though
