FMS Lobes Vs Comp Lobes
Old 01-16-2004, 04:52 PM
Kurtomac's Avatar
Default FMS Lobes Vs Comp Lobes
how do Futral Motorsports cam lobes comare to comps XE and XE-R Lobes? what would the power and tq differences be comparing them?
Old 01-16-2004, 05:23 PM
LSX Mechanic
Damian's Avatar
You probably won't find much information on this topic. Alan designed the lobes for his cams, and doesn't discuss them openly (I wouldn't either)....
I can say this, Cam Motion owns
Josh
Old 01-16-2004, 05:28 PM
Beast96Z's Avatar
Alan does use Cam Motion, and if I had to say, It would be closer to XE-R spec. Just a guess though. Cam Motion puts out some hard sh*t.
Old 01-16-2004, 05:41 PM
Linear Velocity's Avatar
Buying directly from Com Motion would be no different than buying an FMS cam, right? AAP used Cam Motion too
Old 01-16-2004, 05:45 PM
LSX Mechanic
Damian's Avatar
Wrong. Alan's cams are a specific lobe that HE orders...
Old 01-17-2004, 12:23 AM
Candy's Avatar
Yes we use Cam Motion for our cams, most of the lobes that we use were designed for FMS using the criteria Allan specified, so therefore those particular grinds are only available through FMS. Cams are very difficult to compare, they are much more than duration, lift and lsa. If you want to compare our lobes to Comp I would say they would be more comparable to the LS1 High RPM series.
Its hard to compare in general what each cam would do but the biggest difference in our cams is the power through the mid-range and ability to remain stable in upper rpm's.
Hope this helps some.
Old 01-17-2004, 12:56 AM
Originally Posted by Candy
Yes we use Cam Motion for our cams.
Damian
Old 01-17-2004, 09:17 AM
UnbelievabLS1's Avatar
Damian
If you'll notice a few posts up, Damian says "Cam Motion owns", meaning that's who Alan uses to grind his cams. His reply to your question about just ordering any LS1 cam from Cam Motion would be pretty him telling you that YOU were wrong, in the fact that if you did order just any LS1 cam from Cam Motion, that it wouldn't be one of Alan's grinds, therefor not on his lobes, or any of his design specs. Pay attention a lil more next time.
Old 01-17-2004, 09:47 AM
gator's 99TA's Avatar
pony up and spend the money for FMS' time. that R&D is worth it.
Old 01-17-2004, 11:42 AM
LSX Mechanic
Damian's Avatar
Damian
LOL......Read a little more chief....
Yes we use Cam Motion for our cams, most of the lobes that we use were designed for FMS using the criteria Allan specified...
Old 01-17-2004, 09:10 PM
Well I've seen a cam card for an FMS cam and one of AAP cams they are identical. I'm sure FMS developed some lobes there but of course they're going to want you to buy from them as opposed to cam motion.
Old 01-17-2004, 09:14 PM
Ron@Vengeance's Avatar
If you read back, Candy said MOST of their cams have custom FMS lobes. She didnt say all.
Im sure FMS would prefer you buy their cams from them, as Im also sure LG would prefer you buy his G5X2 from him instead of Comp......
Old 01-17-2004, 09:24 PM
NA$TY-TA's Avatar
Damn Ron............................................... LG................. ha ha
Old 01-17-2004, 09:29 PM
Whaaaaaaaaa........ Just making a comparison...
Old 01-17-2004, 09:59 PM
Shorty Director
VINCE's Avatar
FMS-9 cam is all I have to say..
Old 01-17-2004, 10:29 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
FMS cam question...
If a 224 XE-R idles like a 222 XE, a 228/230 FMS idles similar to?
~226 XE-R?
Old 01-18-2004, 12:08 AM
GrannySShifting's Avatar
Seems like the last one i fooled with idles like a 228/230 cam, didnt seem any different. Hey Alan/FMS, could you shoootme a PM sometime?
Old 01-18-2004, 01:38 AM
Black02SS's Avatar
FMS cam question...
~226 XE-R?
My 228/230 rides better then my 224 XE-R. No surging, nothing. Car actually drives like stock.
Old 01-18-2004, 12:19 PM
HC02SS, thanks that sounds very encouraging. I have a 224 XE-R on a 113 LSA that's very nicely mannered. If FMS 228/230 on a 114 or 115 wouldn't push the peaks too high that might be my next cam.
Old 01-18-2004, 01:19 PM
LSX Mechanic
Damian's Avatar
Make sure you get some advance ground in, and you'll be fine. A 114+4 would idle like stock, and still make PLENTY under the curve..
FWIW my cam is on a 114+0 and the graph is still nice and fat
