having trouble determining what is causing my low oil pres. problem plz help
hey guys having troubles thought maye someone could help. last year had a motor blow up and then did a rebuild. everything was good after the rebuild. but this spring when i got the car out my oil pressure was about half what it should be. and everything as good before it went in storage. first thig was placed a mech gauge on it and it read equal to the OEM one. then replace the pump with a melling pump and still have the same issues.
Now today i pulled the motor an dropped the pan, found that the pick up tube had some gunk in it but not a rediculous amount. could this be what caused my low pressure problem? or could it be the infamous Oring? Any info would be great.........
Thanks Jason
Thanks Jason
