Need Some Advice
Need Some Advice
I have a 01 5.3l/4l60e in a 99 Grand Cherokee with 38.5" tires & 4.56 gears. The engine has just developed a rod knock. The guy I bought it from will give me another engine for free. I was thinking I might sell the one he gives me and get a 6.0l. Or maybe cam the 5.3l
I daily drive this thing so I want to keep driveability good with nice low RPM power. With the stock 5.3l from a dead stop, mash the pedal and it's gutless until it gets moving. I know I can't expect too much with my tires and gearing.
So would I be better off camming a stock 5.3l or dropping in a stock 6.0l. If I sell the 5.3l I'll have to cough up $500-600 extra for the 6.0l
Thanks for the advice.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Those 38.5" tires are defintely making it gutless! Even with a low ratio like you have. There probably isnt going to be a real giant difference in the 5.3 and 6.0 as far as your application goes, but anything is an improvement over the 4.0 that you had originally. Next thing on your plate will have to be swapping out that 4L60.
Thanks guys
I have thought more and figured I'm going to cam the new 5.3l. It's got 150,000km on it, should I re-ring and bearing it too? Trying to keep this as cheap as possible.
Can you guys recommend a good cam? I mostly drive in town, to work and back (5km each way), low speed. I run trails and crazy stuff. Want LOW rpm power and as good of fuel mileage I can get for what it is. Believe it or not, the 5.3 now with the 38.5s is better on fuel than the 4.0 with 36s
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Welcome to the efficiency that is the LS platform!
