Heads/Cam, what kind of power through an A4?
Just curious of what kind of power I should expect to see. Being in Jersey ill need to stay sniffer friendly. Been looking at TSP's 224 Cam and possibly there ported LS6 heads (willing to take other reconmendations).
The track is the true dyno. Auto's with high stall's don't dyno well - period. Don't believe all the hype you read here and on the internet. Dyno's # are played like a good fender strat.
See my sig...And these are very NOVICE times with bad shift parameters.
Ah yes you do, my set up on NA my tuner has seen run 440ish and with the 150 shot closer to 600 through an M6.
You loose 30% through drive train parasitism on an A4 than the 15 to 20% at the most through an M6
Yet OP don't worry too much about numbers too much if I where you. I guarantee even if you had matching rwhp numbers you will out perform an M6 on the track 9 out of 10 times. Once in a while you'll get a guy who can really bang gears but the A4 will almost always win out. Take it to the track and come back and let us know how u did. You will be pleasantly surprised.
I agree that auto's will outperform M6's with more HP, but that's only if the auto has a good stall converter.
http://www.converter.cc/tech_talk/
I made the numbers in my sig on a load-bearing dyno and big wheels, cam is 228/232 and CNC'd 243 patriot heads. Tuner said it would easily be over 400 if I had smaller wheels. I have since added a ported fast 92 and a stall and waiting to get back to see the new numbers. But from what I have read, 390 on a load bearing is similar to 420-430ish on a dynojet.
But like already mentioned, autos will dyno lower, esp. with a stall, but track times are more accurate as far as how fast it actually is.
Yes, you do.
I was making 370Rwhp (226/228 .588 114 ported/milled 317s 4000 converter 373s full bolt ons).. Knocking on 10s back door. 3450# race weight in 2000+DA.
I am now making right at 400Rwhp.. Should be in the 10s, same race weight.
Rwhp #s mean nothing.. It is all how the setup is matched. A correctly built setup will run much better in a setup with parts just to make a high Rwhp number.
Pay attention to parts that compliment each other, not parts that make Rwhp.
