crank cost
Old 06-30-2010, 02:41 PM
2000RDT/A's Avatar
Default crank cost
about how much does a stock crank for a 2000 ls1 cost? or where is the best place to get one? getting my motor rebuilt and they are going to need to weld one journal and is expected to cost about 500 bucks. didnt know if i could get a new stock replacement for about the same. id rather go new then worry about the weld being crappy and chucks falling off
Old 06-30-2010, 02:51 PM
Darkman's Avatar
Texas Speed has LS1 cranks in the $800-$850 range. Considering the labor cost/time of replacing a bad crank the $300-$350 extra would be well spent.
Old 06-30-2010, 03:07 PM
2000RDT/A's Avatar
i saw these but i think they are forged cranks arent they? im looking for an oem crank if possible. thanks tho. still may end up going with a forged one
Old 06-30-2010, 03:25 PM
Darkman's Avatar
Rock Auto sells Marshall (brand) remanufactured LS1 cranks for just under $400.
Old 06-30-2010, 04:37 PM
408z28's Avatar
I have a ls1 crank std/std in great shape, 62,xxx miles ill sell for $100 + shipping.
Old 06-30-2010, 08:47 PM
427's Avatar
New GM crank is around 400.
Kurt
Old 06-30-2010, 10:06 PM
garygnu's Avatar
SDPC should sell them.
Old 06-30-2010, 10:23 PM
pstexas2's Avatar
Thumbs up
just wondering will a ls1 forged crank fit a 6.0 iron block
Old 06-30-2010, 11:52 PM
2000RDT/A's Avatar
thanks guys. im probly gonna go new. more peace of mind
Old 07-01-2010, 10:44 AM
KCS
Moderator
KCS's Avatar
Callies has 5140 stroker cranks for about $530 new...but then you need rods and pistons too.
Old 07-01-2010, 10:47 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Yes, they are interchangeable!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-01-2010, 02:34 PM
2000RDT/A's Avatar
no stroker for me. im trying to stop my wallet bleeding now after a rebuild with heads and cam swap. not enough to do everything
Old 07-11-2010, 05:45 AM
wrea398's Avatar
Default Re
Just bought a fresh 10/10 2116 Corvette crank kit with Clevite rod and main bearings in the kit for $350.00. Standard Crankshaft in NC. Prices included shipping 25.00 and core charge of 45.00. Local Napa Stores and some Autozones etc. get them from Standard too. Correct crank with gun drilled mains. Clevite bearings go for over 100.00 a set alone. Included in kit.
Quick Reply: crank cost
