Installing Stg 2.5 5.3L heads on 98 LS1, have questions...
I'm getting ready to install some PRC Stg 2.5 5.3L Cylinder heads that have 59cc chambers. I'm using gm mls head gaskets. I'm going to have 11.5:1 Compression ratio according to calculations. Is that going to be too much for 93 octane?
Also, whats the biggest camshaft you can run without having to flycut the pistons? I am going to check ptv clearance and all that stuff but I just want some advice before I dig into the project.
Chris
Chris
The cam in question is like 234int/240ex .598int/.608ex on a 112 lsa
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Thats what I'm afraid of. I have been reading 228 cams are on the safe side of things. I was planning on running the same custom cam my buddy's car has in it with the same heads. But I'm thinking his heads are 62cc and not milled versions like mine.
Cool well I pm'd Matt from Texas-Speed. I have all the tools to check PTV and pushrod length, I'm just trying to do all the thinking before I dig in and get my hands dirty.
Would it even idle with all that extra air? If mine runs and idles, Id consider driving it to the tuner but thats it. I have HP tuners and access to some trailers so Ill only drive it onto the trailer. I wouldnt go hotrodding it or anything lol.
Chris
Chris
