Will i have to flycut?
Old 07-04-2010, 12:33 AM
My6speedZ's Avatar
Default Will i have to flycut?
I'm about to pull the trigger on a set of PRC LS6 stage 1 heads.
I will be running them in conjunction with a Vengeance Racing 228/230 .588/.592 112 LSA.
Will i have to fly cut with this set-up?
Old 07-04-2010, 01:08 AM
cabech984's Avatar
Most likely not, but always check piston to valve clearance when you diy. I think you can run an ms4 cam with those heads btw which is bigger
Old 07-04-2010, 01:27 AM
SLP4CamaroSS's Avatar
more info heads milled running smaller head gasket?
Old 07-04-2010, 06:42 AM
vettenuts's Avatar
Install and degree the cam, put on the heads with an old gasket and measure. Only way to tell.
Old 07-04-2010, 10:37 AM
My6speedZ's Avatar
I was going to get the WS6store head and cam gasket package so i am presuming the multi-layer head gasket is a standard GM one.
It does not list the chamber size on their website, i would assume 62cc.
Could milling these to 59cc increase my CR with out the need to fly cut? How about a different gasket as well?
Old 07-04-2010, 10:53 AM
cabech984's Avatar
You will need to check PTV clearance. Thats the safest way to be sure. For reference, I have PRC Stg 2.5 5.3L heads with 59cc chambers and I was told with a stock LS1 and stock MLS Head Gaskets, the biggest cam that Texas speed has put in there is a 228r cam, but they also told me to measure first.
Old 07-04-2010, 11:02 AM
My6speedZ's Avatar
Ok, i am not going to be doing this install myself (lack of time to be honest). I am just really trying to make sure i do this right and wont run into any issues, not that i would have a problem with fly cutting, just wanted to know so i could adjust my budget accordingly.
But thanks alot cabech984
Old 07-04-2010, 12:22 PM
just plan on flycutting then when they say u didnt need it be like a xmas present u get money back lol
Old 07-04-2010, 03:43 PM
My6speedZ's Avatar
Haha sounds like my line of logic, then when i have that extra money left over i'll all be like "what else can i get while im here".
Old 07-04-2010, 04:45 PM
printmanjackson's Avatar
I wouldn't think you would have to cut but I would still check. After you check you can decide then if you want to mill the heads more.
Old 07-04-2010, 05:41 PM
My6speedZ's Avatar
Is there any opportunity to change the head gasket to bump up compression?
