Scat H Beam Rod Pin Diameters
Looking at some Scat H beams and JE pistons. I keep seeing .927 or .945 pins for stock LS dimensions VS. the smaller Chevy standard pin diameter. Both manufacturers offer stock bore/stroke setups and in both pin diameters. Any advantages of one over the other? Just curious. Most likely it won't matter for a 500HP build as long as I match the rod to the piston. Thanks for your input.
