best cam for no2
best cam for no2
i am now runing a 100 hp shot of spray and am still looking for a good cam kit, i realy wanna be close to 500 wheel hp. right now i still have long tubes slp lid cat less cat back and cutout. and the no2. i was looking a texas speed magic stick. but idk i realy want that loby idol.thanks and i am also gunna get the ls6 intake.
I would do the baby EPS the cam is guaranteed 430 rwhp. Now there are many configurations of N/A cams that are good for N20 but not every N/A cam is going to be good for N20. What I would do is get a custom grind that will be used for N20.
While there are a lot of knowledgeable guys here the N20 thread might get you a little more info since those guys know every dam configuration that you might be thinking because they might have already ran it.
I am using an Ed Curtis cam and AI heads and you can see by my sig that its not a bad combo.
Good Luck keep us posted. The one thing though and its my personal opinion and experiene is to stick with a 112 LSA specially if its going to be a DD.
Nitrous cams have a wider duration split than N/A cams. I have a Thunder Racing 230/236 cam and it works well with nitrous. If you drop down a notch at Texas Speed to their 233/239 cam on 113 or 114 LSA, that would also work well and lope would be less radial than the Magic Stick.
Here is a dyno vid of my car, at the very end of the vid you'll hear the idle from back at the tailpipes. Keep in mind I have the A4. If I had a M6 it would probably be 450+ HP. (No nitrous on this pull.)
http://www.streetfire.net/video/batb...run_742242.htm
Do the EPS 234/246 111+3.. should LOVE the nitrous. I'm betting you pick up 120 on a 100 shot.
I have it on a 110, here's the idle vid: http://www.youtube.com/watch?v=YUjsqLht0BI
That's one mean sounding machine and no doubt nitrous will love that cam, but if the OP thought the magic stick would be too much lope, I bet he won't go for that cam.
just make sure your exhaust duration is open longer than your intake you want to make sure you get all the gasses out thats just what i read in a book on how to build nitrous engines since im building a 408 for nos now!
