Trick Flow220 genx heads what rockers?
Old 07-11-2010, 08:04 PM
sabersaw30's Avatar
Default Trick Flow220 genx heads what rockers?
I just got me some trick flow heads just curious what rockers should I run?Can you run the stock rockers?Should I go to the aftermarket rockers?First head swap nervous want to make sure I got everything right before I do it.
Old 07-12-2010, 01:04 PM
KILLERARMY's Avatar
You might need to upgrade your stock rockers with this set of (Comp Cams LSX Rocker Arm Trunion Kit). http://www.ws6project.com/user_stor/...oducts_id=2950
The next level of rockers should be Yella Terra Rockers (YT6645).If you go with the Yella Terra rockers,They are a bitch too located.
Old 07-12-2010, 01:48 PM
SSmoken's Avatar
stock rockers. thunder racing sells a shim / longer pushrod kit. im still waiting for mine to arrive as i have tfs as cast 220's in the garage waiting to get put on. try a search, you might find some more info.
Old 07-12-2010, 02:08 PM
sabersaw30's Avatar
Yeah what size pushrods you got to use.I got some 7.50 trick flow pushrods that came with the heads.I bought them used but it was a whole kit with push rods.
Old 07-12-2010, 02:11 PM
sabersaw30's Avatar
That looks like it would be the ticket for your stock rockers.
Old 07-12-2010, 02:27 PM
SSmoken's Avatar
i dont know what the kit comes with that i ordered. i emailed them to see when itd be here cause its been over a month and they said they were still waiting on the pushrods to be finished
Old 07-12-2010, 03:25 PM
LS1Tech Sponsor
TrickFlowTech's Avatar
We recommend aftermarket rockers with our cylinder heads. We suggest Yella Terra or the Harland Sharps.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 07-12-2010, 10:23 PM
Bad98SS's Avatar
I have TF 225cc and just broke a yella tera rocker, the push rod went right through it. I have 1500 miles on my new 408 stroker. But yella tera did send me a new rocker free of charge.
Old 07-12-2010, 11:39 PM
dbeach2001's Avatar
Default TFS 220 heads & Yella Tella rockers
I just installed a set of TFS 220 as cast heads from Vengeance Racing. I purchased the whole kit from them with their cam, Yella Terra rockers, gaskets, 25% under drive pulley, ARP head bolts, head gaskets and everything needed to do a top end job. The car dynoed 466 rwhp and 420 rwtq. Those heads made a great deal of power. I also installed a FAST 92 and 92 billet throttle body. I would attach a video of how the car sounds with the cam, koooks lts and GMMG exhaust with a OR Y pipe , but i don't know how to convert it to a file that works here. Just go to youtube and look up beachbud37. I have 3 videos of the car running and reving up a few times.
My Camaro really sounds bad ***!!!
Old 07-12-2010, 11:47 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I thought most people ran an aftermarket shaft mount rocker with their heads anyway?
Old 07-13-2010, 12:26 PM
Kevin@Vengeance's Avatar
Most do, and would be the better alternative budget allowing.... but as mentioned, the stock rocker shimmed .090" +/- and a longer push rod will maintain proper geometry on the TFS head.
Old 07-13-2010, 01:25 PM
SSmoken's Avatar
heres your videos. car sounds great.
http://www.youtube.com/watch?v=U7BfDL0p-u8
http://www.youtube.com/watch?v=UHTLMmgmje4
Old 07-14-2010, 03:19 PM
sabersaw30's Avatar
That is some good dyno nos.Who did your tune.I shot you a pm.
Quick Reply: Trick Flow220 genx heads what rockers?
