So I broke my car... bent valve, maybe more?
After some decent passes at the track yesterday I decided to run a wet 100 shot. Normally no big deal right? Well...my car runs very lean so I always jet up 1 or 2 jets on teh fuel side. I had 100 octane in so I figured Id try to go straight up on the nitrous and fuel. I had a great pass...11.40@120 spinning...but I forgot something. Well messing with the plugs last week I broke a TR6 and didnt have one laying around. I had to put a stock heat range plug (autolite) in #1. Well, I went lean, it ate up that plug and I assume the electrode got sucked in, stuck between the piston & valve and to out the valve. Did a blow down test and sure as hell it was leaking. So...how many of you think I'll me getting out of this with some labor and a $7 dollar valve? How many think its a ton worse?
It could be bad, might not be bad at all. Probably have to pull the head and find out what exactly happend. Might change the oil first and see what you find in there. Did you say that the plug actually came apart? I had a friend who shredded a belt at the track (blower), somehow a piece of the belt was stuck in between the valve & valveseat so he was showing no compression on that cyl But he is one lucky bastard. Possibly you just have the electrode stuck inbetween the valve and seat? This is wishful thinking, but you never know.
new plug...still misfiring like hell and throwin codes. Changing the oil and tearin it down a bit later this afternoon.
Thanks for the words of encouragement verbs. lol
LS1TECH Sponsor
i think you should quit the whole racing thing lol between this and loosing the egr gasket down the intake you knew something was gonna finally kick the bucket...buy a nice buick or something and be done with it J/K but really ya need to start being a little more careful with ****.
lata
Bill
lata
Bill
7 Second Club
When I talked with Mike last week he said your car was detonating pretty bad on motor. I told him to get it fixed and tuned before any spraying was done. Did you ever get that fixed or did you spray on it anyways? It sounds to me like more than just a valve is hurt here.
I ran as rich as I could via my predator 5%. Took back 3 degees of timing, and ran 100 octane. The car ran fine and detonation free when I was jetting up on the fuel. But my dumbass decided to run a straight up 100 shot without upping the fuel and she obviously detonated to hell
Mine did the same thing. Itwas melting plugs but the injectors gave up or got clogged. I sprayed it and the burnt a few plugs too. Bad ticking noise like drivetrain and no damage found. No comprasion in #5. I took the head off and I burnt up an exhaust valve nothing else. Stock GM $16 here. But as you can see I couldn't put it back together stock.. Great time for heads and cam! Good luck.
Originally Posted by CANNIBAL
Worse. Possibly a melted/cracked piston, combustion chamber damage, bent valve
