Lm7 internals ?
Old 07-14-2010, 05:22 AM
Simon86's Avatar
Default Lm7 internals ?
Hello
Im realy interested in the lm7 engines, But I wonder is there any rods and pistons to use in it for turbo or does it handle 700hp with std bottom?
Regards
Old 07-15-2010, 07:04 AM
Isolde's Avatar
tirefryins10 claims, if I understood his Mustang thread correctly, to have gotten his Mustang into the high 9s with used stock 5.3 truck block, crank, rods, pistons, pins, rings, bearings and heads. If he NEVER had ANY detonation, then it seems plausible to me. You should shoot him a PM.
Old 07-15-2010, 09:10 AM
pwrtrip75's Avatar
I had a 5.3 for 3 years untouched shortblock w/ 100k+ miles on it. (317 heads and bigger cam) It made 640whp on 15psi and a 50 shot of N2O. 93 octane. I finally spun a rod bearing... stock ones apear to be to soft aluminum. But it was reliable for 3 years, and the rest of the inside looks perfect.
I had a really crappy inefficient converter... im sure the engine produced over 700hp.
Id use all stock parts... maybe swap out the bearings.
thats my experience..
Old 07-15-2010, 09:12 AM
5.3LJimmy's Avatar
The LM7 uses the same rods as an LS1, so you have plenty options for them. Wiseco has pistons for the 3.78 bore with the stock stroke or a stroker setup. You can also bore the 5.3 block as much as 3.905 and use any of the LS1 piston options.
Old 07-15-2010, 09:14 AM
Simon86's Avatar
Haha sounds awsome
Maybe it´s worth a try to run it stock. I read somewhere that the ls1 and lm7 has the same crank and rods ? Just some smaller pistons in the lm7?
Old 07-15-2010, 10:14 AM
Simon86's Avatar
Hehe I think you posted when I was writing. Thanks for the help!
Quick Reply: Lm7 internals ?
