Got the Trex Cam
Old 07-15-2010, 06:41 PM
Docta's Avatar
Default Got the Trex Cam
Hello all, I just had a few questions. I just purchased a Trex Cam, got all the supporting mods for the engine. I bought longtubes and an Off-road Y pipe, SLP Lid, I just need to order my torque converter and 12 Bolt now. The only thing in my way is figuring out what size converter and gears to get. Would a 3600 stall and 3:73 gears be alright? Only current mods are an SLP cat-back and K&N filter. Just need suggestions on those 2 things.
Old 07-15-2010, 06:42 PM
Slash8915's Avatar
Man, with that big of a cam, I wouldn't go under a 4000 stall. As for the gears, 3.73's are the only ones I would recommend for an auto.
Also, I may be wrong, but idk if that cam will clear your heads. What kind of car is it?
Old 07-15-2010, 06:50 PM
Docta's Avatar
2002 Trans Am WS6. I have heard that it will work with stock heads, which is what I have.
Old 07-15-2010, 06:52 PM
Slash8915's Avatar
Stock 243's might be ok. I haven't really looked into ptv clearance with that cam much. But you definitely need a 4000 stall.
Old 07-15-2010, 09:31 PM
somws6bird's Avatar
Agreed no less than a 4,000. Id say do a 4400 with 3.73's
My friend has his setup like that and the car runs hard.
Old 07-15-2010, 09:36 PM
justinj's Avatar
you have duel springs right?
Old 07-15-2010, 09:38 PM
somws6bird's Avatar
Yes I have the 650 patriots. Its def not a good idea to run anything other than dual springs on a big cam
Old 07-15-2010, 10:09 PM
justinj's Avatar
I figured you did.lol I was talking about the guy that posted up.
Old 07-15-2010, 10:12 PM
chon79's Avatar
You should be fine with stock heads on a 2002.
Old 07-15-2010, 10:34 PM
SSTYCOON's Avatar
stock heads are fine as long as the heads have never been removed.
Old 07-16-2010, 05:32 AM
Docta's Avatar
As far as I know the heads have never been removed. And yes I bought the duel springs.
Old 07-16-2010, 08:24 AM
SOMbitch's Avatar
Run a GM MLS gasket and you should clear fine......
Old 07-16-2010, 03:13 PM
NemeSS's Avatar
if you pull the heads, cut in valve relieves. and mill the heads for more compression. the trex responds very well to higher compression.
Old 07-16-2010, 03:35 PM
odarabla's Avatar
The best way to find out what stall is best for your car is to install all the parts you have and then have the car tuned and dynoed. Find where you are making peak torque at and for a street car you want the stall # to be 500-800 rpm less than where your peak torque came in (example: if you made peak torque at 4600rpm then you would want a stall converter built to about a 4000stall) if it is a racetrack only car then you would go 500-800 above where your peak torque is coming in at (example: if you are made peak torque at 4600rpm then you would want a 5200rpm stall converter). Hope this helps..
The only down side to doing it this way is after you get your stall you will have to get the car retuned. Most shops won't recharge you for this if they did the first tune (at least Futral didn't charge me anything extra). The other way you would want to go about doing this is call yank, Circle D or PTC and let them custom build you a converter for your car.
Old 07-16-2010, 03:43 PM
01SS99red's Avatar
go with a 4000 stall and 4.10 gears. thats the only way to go with autos and a big cam. using a 4400 you will lose mph on the top end. good luck
Old 07-16-2010, 03:46 PM
MASS seller approved
smok'nZ's Avatar
are you gonna run a fast intake?
Old 07-16-2010, 11:43 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I would measure your PtV clearance any ways as that is a large cam. I agree that I'd take the extra step, pull the heads, flycut, and mill. It'll be a safer setup that makes more power for only a slight increase in cost.
On the converter I'd go with a 4000 minimum and 3.90-4.11 gears depeding on your tire diameter.
Old 07-16-2010, 11:48 PM
Detoxx03's Avatar
4K stall at minimum
Old 07-24-2010, 02:33 AM
Docta's Avatar
I talked to R.P.M. in Garner, NC. They suggested a Yank SS3600 stall and 3:73 gears with a TRex.
Old 07-24-2010, 06:15 AM
98z8uup's Avatar
The 3600 will work, but 4000 will be alot better.
Quick Reply: Got the Trex Cam
