ANy body have torque specs for arp balancer bolt?
The following users liked this post:
GregM784 (08-05-2021)
Its simple... you put the balancer on all the way, then kind of like a lug nut you zip the bolt on..... You dont sit on it with the impact for a duration of time. The balancer bolt is far bigger than a wheel stud... if you break that your obviously doing something wrong. And obviously you dont use the bolt or the threads to draw the balancer onto the crank. THAT is where and how people F^&* it all up. The impact is a tool, knowing how to use it succesfully is awesome.
What bearings come in contact with the balancer?
It's sad that you get 3 answers from 3 different places that should know. I will say this... the instructions I got with my ATI pin/drill kit say 240 ft/lbs with ARP moly lube. ARP's monly lube directions say to put it on the threads, the backside of the bolt head, and both sides of the washer if there is one.... w/ the LSX there is.
Now if you're pinning the crank you don't need much more than 100 ft/lbs of torque becuase you're not longer relying on the interference fit and the crazy clamp load to hold the balancer in place. Once pinned it cannot rotate and force the bolt to loosen up.
I just installed my 2nd ATI super damper last night (installed one when I put a cam in my old car back in '07) and used an ARP bolt this go around. I used the following procedure.
1. Used my IR impact to get the old crank bolt out
2. Cleaned up the threads and removed the timing cover do do the timing chain and oil pump and drilled for the pin setup
3. Losely installed the timing cover w/ a new front main and red gasket maker on the bottom... had the keyway pin in the crank ready to go
4. Lightly coat the end of the crank w/ anti-seize
5. Thread in threded rod (purchased a homemade pulley install tool off of here)
6. Seated balancer on crank snout, then installed the two washers and nut that were part of the pulley install kit. Used some anti-size on the washer faces.
7. Used a deepwell socket and 1/2" ratchet to seat the balancer w/ the car in 6th gear and back wheels on the ground.
8. Removed balancer install setup then installed old bolt and used my 160 ft/lbs torque wrench and maxed it out then a little more to fully seat the pulley.
9. Then installed the ARP bolt w/ the moly lube per their directions then maxed out my torque wrench at 160.
10. Lastly I torqued the timing cover bolts to spec 18 ft/lbs.
Everything went fine.... using the imact to get the bolt off was a great help, but I wouldn't used it to seat the pulley... that's just my $0.02. Most broken bolts and issues come from trying to run the pulley on w/ the old bolt... using threaded rod takes the risk out of the procedure.
