View Poll Results: What camshaft should i use?
TSP 228r
12
34.29%
EPS 222/226
14
40.00%
Custom Grind
9
25.71%
Other
0
0%
Voters: 35. You may not vote on this poll
228r or EPS 222/226 cam?
Old 07-20-2010, 10:29 AM
cabech984's Avatar
Default 228r or EPS 222/226 cam?
I'm getting ready to do a Head and Cam swap to my 1998 Formula and have been searching for a cam that will fit under my heads without flycutting(checking ptv of course). I have PRC Stg 2.5 5.3L heads with 59cc chambers and am using stock MLS gaskets on the LS1. I've successfully flycut pistons before but just dont have tools to do it anymore and am too lazy for all of that!
Should I go with a 228r cam from texas-speed, or an EPS Camshaft, or other? Help a dude out!
Old 07-20-2010, 10:41 AM
TooLateVTEC's Avatar
Desired power ?
Daily driver ?
Help the brothers out !
Old 07-20-2010, 10:46 AM
garygnu's Avatar
get a custom EPS cam,it will work even better.more power less duration.
Old 07-20-2010, 10:49 AM
Bo's 98 TA's Avatar
Go with the 228r.
Old 07-20-2010, 10:57 AM
thunderstruck507's Avatar
EPS for sure, custom spec
Old 07-20-2010, 11:14 AM
Giddswat's Avatar
The TSP 228r on a 112 lsa is a nice cam with the heads you have, they are a nice proven combo.
Old 07-20-2010, 11:31 AM
fatboyq's Avatar
EPS with the split duration
I would do a Futal F6? 226/230 cam
Old 07-20-2010, 12:03 PM
cabech984's Avatar
Originally Posted by TooLateVTEC
Desired power ?
Daily driver ?
Desired power? What do you think my answer is??? The most possible with what I have. The car isn't a daily driver but streetability is highly desired.
I forgot to add a few other things. I already own a Fast92/92 setup and have #30 lb Ford red tops(36psi @ LS1 fuel pressure) and have already upgraded the rod bolts to Katech rod bolts. Also currently have a 4000 stall converter as well as Pacesetter LT's, ory, and Magnaflow cat back.
Old 07-20-2010, 02:58 PM
99Bluz28's Avatar
EPS, custom cam!
IMO, doesn't sound like you need a large split, and go with a 224 (minimum) on the intake duration.
Old 07-21-2010, 10:46 AM
cabech984's Avatar
Alright, I've decided to see what EPS says, I sent them a custom cam request. Now I'll wait and see!
Old 07-21-2010, 10:53 AM
*02WS6TURK*'s Avatar
EPS once again. 226/234 would be another good choice. I am getting mine from him soon.
Old 07-21-2010, 11:03 AM
desertLS1's Avatar
Glad you decided against the Torquer 2
To the OP, you should also consider a Cut out!
Old 07-21-2010, 11:05 AM
Josh@PremierAutosports's Avatar
We have done many cars with a 228/228 camshaft and its a fantastic cam for great driveability and good power. Yes other cams can make more power and others less. All depends on what you are looking for out of your setup. Since you have a 4k stall it sounds like you are willing to give up a little stock like driveability for performance. You mise well go a larger then as long as you have a good tuner.
Old 07-21-2010, 11:59 AM
cabech984's Avatar
Oh yeah, I have one of those too!
Old 07-21-2010, 12:01 PM
Lol...why is that? Your not a fan? I have my reason why, just don't wish to express them on the forums because I'm sure it would make a few upset
Old 07-21-2010, 12:56 PM
cabech984's Avatar
I actually want to restall the converter to 3600ish rpm but funding isnt gonna allow that at the moment since I have to pay the 400 for the cam and 400ish for a tune.
Old 07-21-2010, 01:22 PM
Justus67's Avatar
I'm a big supporter of the TSP 228R, but its hard to beat a custom grind when your wanting a little more performance than an off the shelf cam. IMO Patrick G is the man for a custom spec. Predator Z is very knowledgeable also.
Old 07-26-2010, 05:17 PM
cabech984's Avatar
Alright, just got off the phone with Geoff at EPS and he recommended a 226/234 grind, so I pulled the trigger on it and we'll see what we get!
Old 07-26-2010, 09:15 PM
Alba Gu Brath's Avatar
That makes two of us...paid for mine today too! Looking forward to it...that's 2 known Ohioans with EPS cams...lol
Old 07-26-2010, 09:19 PM
cabech984's Avatar
What did you end up getting? I'm from Dayton
Quick Reply: 228r or EPS 222/226 cam?
