Callies stroker crank too cheap?
Callies has 2 forge cranks. 4030 or what and a 5120 or something like that. The 5120 is about 200 dollars cheaper. Maybe he is seeing that. Yes its a 4" stroke. I talked to Erik at HK about this crank. He said its good for NA and even small nitrous shots. Both are good just depends on your goals.
LS1Tech Premium Sponsor
I'd put their 5140 cast crankshaft alongside Eagle and the other budget cranks as far as machining quality and all. Don't be horribly shocked if it needs turned to make those journals perfectly round....we have seen it fairly frequently with the Eagle and Scats too.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If you are looking for common stroke stuff they have a plan to stock those. The custom stroke stuff may be a little wait, but that happens with Sonny also. The Callies has a taper in the center weights that saves a bunch of work fitting the crank in the block.
Kurt
Kurt
