Where do I get a crank pulley?
Other than buying one used, where can I get a new harmonic balancer/crank pulley? I have looked high and low and been to all the auto stores (napa, pepboys, orielys, advance and autozone) with no luck, even looked online and couldnt find one. anyone know of a place? thanks.
Its not really a wearable item so no one likely picked it up on the aftermarket (for a stock replacement). Your best bet IMO if looking for a stock type replacement new would be an ATI 10% underdrive unit. Quality would far exceed an OEM piece and you get an SFI rating with slightly longer accessory life.
Thanks for the help guys. Summit sells one for $60 so I'm gonna go with that one. Thanks again!
http://www.summitracing.com/parts/RNB-594-127
01, 594127, autozone, camry, crank, crankshaft, g35, gn, good, ls1tech, m6, performance, pulley, pulleys, replacement, rnb594127, underdrive
