Main bearings still alright to use?
Old 07-26-2010, 10:54 PM
Hanzy98LS1's Avatar
Default Main bearings still alright to use?
I got a seat of OEM main bearings that came on a block and guy gave them to me in a bag. I'm not using them on my build but whanted to find out if there still dood. There's not much were on them but the bearings bein in a zip lock bag they rubbed together and now have surface scratches on them are thay good to use or should I chunk them? It's not deep or anything but you can se the scratches goin against the machinig??
Old 07-27-2010, 01:14 AM
Adrenaline_Z's Avatar
Replace them. They are cheap.
The crankshaft will need machining if it's used, which will require oversized
bearings.
Be sure to check the clearance with a dial, or at least plastigage before
zipping up the engine.
Old 07-27-2010, 03:14 AM
96lt1m6's Avatar
Once a motor is pulled apart the bearings and rings should get disposed of....
cheap insurance to replace!
Old 07-27-2010, 12:36 PM
Hanzy98LS1's Avatar
Sweet il chunk them Im probly not going to use the stock crank but I was thinking bout puting what I have together just mok up for practice thanks guys!
