Next mods? Heads/intake?
Old 07-29-2010, 01:33 AM
FiveOhhEatr's Avatar
Default Next mods? Heads/intake?
My buddy has a 2000 ws6. The car has 85k on it, whats the next step. Forced induction is out of the question and so it nitrous (for the moment). We were thinking ls6 intake, heads, and throttle body. budget is probally going to be around 3-4k over the winter. Mods listed below:
-6 Speed
-LT Headers
-cutout
-comp cams 238/242 .600/.610 @ 112+2 LSA cam
-slp lid
-strange s60 4.11 gears
-upgraded fuel system
-sub-frame connectors
-driveshaft safety loop
-slicks
-pro 5.0 shifter
Old 07-29-2010, 02:28 AM
Adrenaline_Z's Avatar
You can't go wrong with heads and intake; it will really make use of that
camshaft!
I'd even suggest getting some more flow from the rest of the exhaust
system as there's really not much benefit of having all the good stuff
under the hood if the exhaust is restricting the power potential.
Old 07-29-2010, 02:56 AM
SIC LSX's Avatar
ls6 intake, port ya own TB, heads, k-memeber, Qa1's
Old 07-29-2010, 03:19 AM
Squirts11's Avatar
Ported/vj'd 243's, look for a decent deal on a fast intake/tb (honestly, you really need it for that cam to show its potential), and while I don't know much about manual cars, if you plan on making decent power, I'd imagine you'll need to upgrade the clutch, master/slave cylinders as well.
If you do the work yourself, which isn't bad, you'll be hauling ***.
Other than subframes and DS safety loop, is the suspension otherwise stock?
Old 07-29-2010, 06:23 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Used LS6 Intake
P&P TB
Heads
Retune
good to go.
Old 07-29-2010, 02:01 PM
ya suspension is otherwise stock, it needs new rear control arms since one side is bent. were picking up a BMR torque arm for $100.
What do you guys think the car will make to the wheels with the heads, intake, and ported throttle body?
Old 07-29-2010, 02:05 PM
Internet Mechanic
Depending on Tune, head choice, compression anywhere between 390-450 rwhp
Old 07-29-2010, 02:11 PM
Well the car dynoed at 400rwhp
Old 07-29-2010, 02:13 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Some new heads and a FAST intake will work wonders with that cam. Extra compression should really pick it up!
Old 07-29-2010, 04:29 PM
any specific heads to go with?
Old 07-29-2010, 04:42 PM
c5z28's Avatar
worked 5.3's I just happen to have some for sale
Old 07-29-2010, 04:56 PM
If its in the budget you should go aftermarket casting. PRC, AFR, or TFS all have good aftermarket casting heads that will work great with the cam you are working with. These heads all have thicker decks, smaller runners, and larger valves. The thicker deck allows for more clearance so you can run large cams like the one you have and not have to flycut. The smaller runners move the air at a faster velocity giving more low end power and throttle response. Send me a PM or give us a call at the shop and we can go over it in detail.
