Is there anymore to be gained from porting
a set of AFR heads since major R&D went into designing these things. Will there be such a thing as them being "cleaned up" (CNC version) and should one pay for that? Would touching them help or hurt them. The way i see it the only thing that needs to be done other than bolt them on is the mill them to get the desired compression ratio. What are you alls thoughts on this?
