Anybody have experience with Mahle piston rings?
Old 07-31-2010, 06:26 AM
99 Blue Bird's Avatar
Default Anybody have experience with Mahle piston rings?
are they any good? i want to buy some pistons and was wondering how good these r cuz they come with the Mahle pistons.
Old 07-31-2010, 11:26 AM
KRAZY K 2000 TA's Avatar
they are a very good company i wouldnt hesitate to use them.as long as your ring end gaps are properly set and you have a good cross hatch on your cylinders your fine.
Old 07-31-2010, 12:06 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I think it depends what you are doing. Mahle builds a great piston but it does not feature the same forging as some of the other brands out there. If you are looking to hit the motor with some heavy nitrous or boost I would recommend looking into a Wiseco or Diamond piston. They come with a stronger forging, and the Wisecos even come with a GFX steel top/napier 2nd ring set.
Old 07-31-2010, 03:50 PM
well i am thinking about running a 200 wet shot in the motor max. probably a 150 jet most of the time. but the thing is im gonna build a LQ4 .30 over with the stock rods, and im gonna top it off with a LS3 top end. i have only seen like two different pistons that i can actually use. im looking for a flat top with a little bit of valve relief. i came across some diamond pistons that i belive would work for me but it didnt tell me how much relief was in them. thats why i asked about the Mahles.
Old 07-31-2010, 11:30 PM
brooknasty's Avatar
Mahle is a good product. I am using their pistons and rings in my LS1 camaro.
Old 08-01-2010, 01:04 PM
JPH
JPH's Avatar
There pistons are awesome, and there rings are perfectly flat and square for superb sealing. But I got to warn you, the oil rings can be a **** to put on though.
Old 08-02-2010, 06:16 PM
anyone else have some insight?
Old 08-03-2010, 04:06 PM
jmm98LS1's Avatar
I run mahle pistons/rings in my 370 with a 200 shot......they make good stuff.
Old 08-03-2010, 07:25 PM
SOMbitch's Avatar
HKE decided to go with Wiseco GFX pistons & rings in the shortbock they are building for me.....
Old 08-04-2010, 06:41 AM
Bobsmyuncle's Avatar
YES!!!!, theyre a pain. i gapped, ringed and installed all of them in about 6 hours.
Quick Reply: Anybody have experience with Mahle piston rings?
