Best heads to match and work well with my cam.
Old 08-01-2010, 12:04 AM
bigfatls6's Avatar
Default Best heads to match and work well with my cam.
I recently installed a cam in my 2001 z06. Im now looking to upgrade from my stock ls6 heads some time in the near future to some thing that will work well with this cam and supporting mods. Here is what I have now.
231 237 .589 .595 112 cam
Fast 90/90 intake and t.b.
Lg street headers with catless xpipe
B&B prt catback exhaust
25% under drive pulley
New ls7 lifters
ls2 timing chain
ported ls6 oil pump
Old 08-01-2010, 12:24 AM
garygnu's Avatar
what are the head casting numbers on the current heads?
Old 08-01-2010, 12:53 AM
180ls1's Avatar
I would just send your heads off to west coast cylinder heads to have them ported
Old 08-01-2010, 01:19 PM
JPH
JPH's Avatar
Have your #243s worked on, or buy a set of AFR205s or TFS215s imo.
Old 08-01-2010, 05:30 PM
bigfatls6's Avatar
243's
I have thought about it but I really don't want the car to be down for a month or more. I have located a set of 799 casting heads which are the same as my 243s but I need to get some pricing together to see if it would even be worth buying the extra set to have ported.
Old 08-06-2010, 10:55 PM
bigfatls6's Avatar
To the top does any one else haave any input? I already bought a set of new 799 casting heads to have done by prc. SHould I have them milled and if so how much?
Old 08-06-2010, 11:06 PM
12 Second Truck Club
06tx4.8's Avatar
im local in houston...monday, call jeff over at westside machine. have them put bigger valves in and do a port job. they do awsome work, and they will be local for u. here is their #.......713-465-7996....after u have them do ur 799s, sale ur 243s and make some money back!!
Old 08-06-2010, 11:07 PM
06tx4.8's Avatar
i would have them milled to 62cc, would give u about 10.75:1 cr, have them put in 2.02/1.575 valves
Old 08-07-2010, 04:09 AM
fatmat80's Avatar
I would have my 243s ported by a reputable porter like TEA, WCCH, cartek or PRC..Or if your on a budget you could get some tfs 220 as cast and later you can have those ported by TEA..jus my .02
Old 08-07-2010, 08:25 AM
BaddBird's Avatar
bigfatls6
IMO I would send my 243s to Tea, if they already have the lightweight valves in them. If you mill them .020 and use .051 mls gasket that will give 11:1
Unless your runnig a thicker then stock head gasket 62cc would give 11:1. Not sure about how much clearence that cam has but if you mill and go with oversized valves you need to measure for PtV.
Old 08-07-2010, 11:49 AM
The_Rizzle's Avatar
01 z06's didn't get the lightweight valves, so it won't matter if he gets the 799's worked over or the 243's. Would for very little downtime, and can sell the 243's if he wants.
Old 08-07-2010, 02:00 PM
BaddBird's Avatar
I stand corrected. For some reason I was thinking 02 Ls6.
Old 08-07-2010, 02:36 PM
n20kid's Avatar
They are already 61.7 or 62.7 cc from the factory...
And if i were u i would get a set of 215cc 11 degree PI heads, there isn't another head on the market that compares...
Old 08-07-2010, 03:03 PM
BaddBird's Avatar
? Unmilled 243s are 64.45 to 65cc from the factory.
Old 08-07-2010, 03:26 PM
LS1ROPER's Avatar
TFS 215 Hands Down!
Old 08-07-2010, 05:25 PM
mike c.'s Avatar
If you want power,go with after market heads. AFR 205 heads got me 40hp over a stock ported head from a top sponsor. TFS 215 heads will also be great. You can port a stock head and it will just be a stock ported head. Aftermarket cost more for a reason and are worth it.
