my motor sounds like a sewing machine ...normal for an LS ?
my engine is a 03 6.0 lq4 w/ texas speed 2.5 ls6 heads (cut .010 ) and there
T3 cam , LS7 lifters , 7.4 pushrods
the top end of my motor sounds like a sewing machine , very noisey is this normal after a head and cam change ?
car runs mint , makes good power , oil psi is good ( 45-50psi on the highway/ 30-35 idle ) ran 10.91 @ 125 friday night
pushrods too short maybe ?
LSK on the intake, and XER on the exhaust. The fast ramp rate of the LSK will make some noise! Just to be safe though you should always measeure your preload. One of our sponsors has the comp cams adjustable pushrod tool for $15, cheap asurance.
