6.0 budget build
6.0 budget build
Would it be possible to use a 6.0 stock crank, rods, aftermarket pistons? Bore the block to 370-372 c.i., balance the rotating assembly, add the zo6 cam or the old man stealth cam, do a mild port job to 6.0 heads,do a 3 angle valve job, add matching springs. through a good exhaust system and a good tune, make 450-460 streetable hp.( naturally aspirated.)
Thanks in advance for everyones input.
Originally Posted by robertbartsch
..aren't some early 6.0 cranks different from 5.7 canks...i heard some earlier cranks dont interchange....
1 Post
I'm doing one similar.
6.0L block, 6.0L crank, Manley rods, Diamond pistons, my LS6 heads that I already have (radiused for the 4.0 bore), and a custom ground cam (not huge, but not stealth either).
I will have 10.8:1 CR. I'm hoping for 425rwhp or so - depends on how the cam grinder did I guess - we'll see!
6.0 project
Are you going for a stealth approach?
6.0 budget build
thanks for everyones input, please keep it coming. i want to do it right the first time.
Originally Posted by VINCE
To meet your 450rwhp to 460rwhp stealth goal I am afraid you would have to go bigger than a 372ci. I suggest a 408ci. You would meet your horsepower goals and can use a small cam. You would most likely easily pass emissions.
I dont know guys, dont forget the great numbers that Tony (Nineball) had with his initial 382 all bore setup. I think he made 450 RWHP with a little 221/221 .558/.558 camshaft. I would bet that 372 could easily absorb a TR 224 on 114...With a good set of heads I think it might make 450RWHP ??
why wouldnt it make 450 RWHP? With so many others making that or near that on cams smaller then a G5X2. Yes it will be difficult, but i bet he could do it with something like a TR224 114 and some great heads. Hell, with a matched intake to the heads, ported tb, electric water pump, carbon driveshaft, great tuning and a great set of emissions legal Long tubes i bet it could be done. Make your power in the heads
6.0 budget build
I have ported several sets of heads in my time and all of them have made very good power, I really think that with the right cam and the other things that i mentioned, such as a good exhaust and tune it could very well happen and on a lot less money than a stroker kit. thanks to every one that replied to my future budget build. Keep the sugestions coming on the proper cam i should use.
John
Shorty Director
There are guys on this board right now with a 370-372ci NA setups. They have all the best parts. They all have a cam a lot bigger than you want and they make what you are talking about making. As for stealth? I doubt there setups are considered stealthy. Now I would be happy for you to prove me wrong. That would make life a lot easier for all of us. To give you an example:
"A particular 370ci motor has a 4.03" bore/iron block, stock crank, Diamond pistons, Lunati rods, Absolute Speed heads, and a Comp 242/248 XE-R and it put down 463rwhp/415rwtq with the NEW FAST intake. With the LS6 intake it dyno'd 456rwhp/410rwtq. "
Notice the big cam and Absolute is known to put out some impressive heads. You mentioned putting in the Z06 cam or one of the Stealth cams.. Compared to the cam the above user is using the Z06 cam is a baby cam.
JJ, i think to maximize your N/A power, you would have to get a reverse split pattern cam. larger duration and lift on the intake side. since you have an M6, 112 lsa should be good on idle. i know you want streetablity, but if you get a nice size cam, it can be tuned to be livable.
I can shift faster than you.
I do agree with the posts above that you can get away with a TR224 cam in a 37x ci. setup and still sound relatively stock.
Shorty Director
Originally Posted by Jason99T/A
Vince, those numbers you listed above were through a Ford 9"/4.56s, 3.5" driveshaft, and 17x11 Fikse with some heavy-*** BFG tires. So, the setup is loosing alot through the drivetrain.
