old short LS1 sleeves...4.125 stroke...whats the best rod/piston for BDC support????
This is for an engine rebuild. Sleeves are the old *** LS1 sleeves from 2001/2002. 4.125 stroke Cola crank.
Best combo rod/piston to keep the bottom of the piston as high up in the cylinder at BDC?
Wiseco has some well designed pistons for the 4.1" and 4.125" cranks. PM Brian Nutter here, he works for Wiseco and was a huge help with my 4.1" crank and 6.125" rods. It uses a little oil, but only about .5-1qt every 4 or 5,000 miles.
