Re-use head gasket?
Re-use head gasket?
I just installed new head gaskets and bolts... long story short one head needs to come back off. I will use new head bolts due to the torque and turn design, but how about the gasket? The engine was not started of filled with coolant.
Thanks
Thanks
LS1Tech Premium Sponsor
All you did was clamp down on them....Reuse, no worries! People do this ALL THE TIME when cutting valve reliefs, if they make a similar mistake during install, etc!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Since only clamped & not run, spray top & bottom of gasket w/ copper gasket spray & re-use. Copper spray will take care of any flake voids that may have occurred when you pulled the head..
LS1Tech Sponsor
Really? For a single 4 bolt cometic gasket, we sell them for 72.95.
But that is beside the point. I meant if he was using the less expensive gaskets, then there is no reason to not get another one. In the end it may not hurt anything, but alot of people pay extra just for peace of mind.
To the op. Yes, they can be reused but they have already been seated. Removing the heads and reusing the gaskets is just not a safe practice. If a little dirt gets on the head, or gasket that's already been seated it could cause a gap in the seal causing coolant leaks, compression leaks ect... The bolts are designed to be a one time use. They are made to be tossed after they've been torqued and then removed. Its up to you though. Its your car, and your hard earned money.
