450hp+ Smog-legal engine combos
Old 10-12-2010, 10:51 PM
sixt9er's Avatar
Default 450hp+ Smog-legal engine combos
Lately, I have been getting a lot of inquiries about late-model engine builds. I'm in California, so they HAVE to pass CA State SMOG laws. I wanted to see what are some good combinations that make 450 or more hp, but still pass the strict SMOG tests. Please list your NA, head/cam/compression combos with the hp rating. Thanks for your help.
Old 10-12-2010, 11:06 PM
Arc00TA's Avatar
My old car with a stock LS6 longblock and a 224 cam passed the sniffer and made 425rwhp when I put the headers back on. Would probably make around 380ish with stock manifolds and cats.
My bets for most of the big power smog legal combos would be getting an LS2/3/7 swapped and BAR'd.
Check out the GMHTP website, they have been working on a smog legal build, with AFR 205's LS6 cam, and some other stuff. It made close to 400 wheel with stock manifolds and cats and all smog equipment. They just started putting an STS kit on there, as that is smog legal. As well as some of the procharger kits are.
Old 10-12-2010, 11:17 PM
sixt9er's Avatar
I was thinking about doing 6.0L, with 243 heads and of course, an aftermarket cam...just not sure about how much camshaft to run, when dealing with the smog laws...sounds as if you have a pretty stout set-up for the street...
I was trying to stay away from the forced inductions for now...most inquires come from people wanting to do heads/cam/intake/throttle-body, etc. stuff.
Old 10-31-2010, 03:15 PM
408Maro's Avatar
im interested in this aswell..my goal however is to makeor even very close to 400rwp with a small cam and maybe headwork with stock manifolds,cats and pass smog..is it possible?
Old 10-31-2010, 05:19 PM
ringram's Avatar
TR Cheater package with AFR heads!?
Old 10-31-2010, 08:08 PM
garygnu's Avatar
talk to Tony M. or Patrick-G ,they could do it for a price.Afr and the right cam.
Old 11-01-2010, 08:33 AM
Steve Gunn's Avatar
Not saying it's impossible, But 400 rwhp is a more reasonable expectation. If you're going to pass a strict visual, the cats need to be in their stock location. This limits you to CARB approved shorty headers in California. With some badass heads (91 octane limits you to too much compression/milling), 224ish high lift cam on a 114, a great tune and all the supporting bolt on stuff (EWP, UD pulley, ported TB, cutout, etc.) you might top 400. I think you'll have to spray it to top 450....
Now if your car is fairly lightweight, with good suspension, gears etc. 400ish rwhp is no joke.
Old 11-01-2010, 08:40 AM
Chrome355z's Avatar
I'd shoot for 400rwhp and put a moneymaker kit on it and spray 50-100hp.
Old 11-01-2010, 04:49 PM
JoshuaGrooms83's Avatar
im interested in this one too. im aiming for 400 myself with N/A and streetable manners. of course, im not limited to cali rules though, but id like to stay as close to legal as possible stilll got my EGR and AIR hooked up to my LT headers lol and got HF cats on my y pipe... mostly for sound purposes... and smell. but 400 range would be nice to get into with heads and cam. jusst dont know which to go with.
Old 11-02-2010, 12:28 AM
fatmat80's Avatar
450 is a little high for smog legal. 400 is doable. gonna need the gas or sts or p1sc if u want more.
Old 11-03-2010, 10:19 PM
sixt9er's Avatar
I hear you guys. I do appreciate your input. Stock Z06 'Vettes come with 405 hp. I'm thinking that with an after-market cam, re-tune and headers, 450 is way doable. I'm not really fluent in cam choices for these LSx engines, yet. Haven't built too many smog-legal, LSx vehicles either. Not too sure about how aggressive I can get with camshafts.
Old 11-03-2010, 10:32 PM
DaveX's Avatar
If you are talking crank hp it should be fairly easy.
Old 11-03-2010, 10:35 PM
sixt9er's Avatar
Yes...of course...450+ at the crankshaft....I failed to mention that in the OP.
Old 11-03-2010, 10:48 PM
firechicken76's Avatar
400 rear wheel hp @17% drivetrain loss is almost 470 crank hp.!
you really only have to make 385 to the tire to make 450 crank hp.
Old 11-03-2010, 11:50 PM
mdpalmer's Avatar
I have the same question as well... don't have the car running yet, but I have a 224/288 cam 114 LSA +2 (or something like that) w/ heads similar to TSP stage 2.5, stock block, pistons/rods, have to run stock manis and cats, CA legal. Gonna try to have this thing on a dyno by next spring, I'll let you know how it turns out. Shooting for 350-400 whp in 2900# car ('93 Mazda rx-7). Real goal is to run the 1/4 high 11's @ ~115-120 mph.
Old 11-04-2010, 01:06 AM
I would think cam alone you could hit high 11's. Im running a low 12 in a 3100 pound third gen, and I just have bolt ons and gears.
a full bolt on car should be around 350 rwhp, cam and bolt ons should be 380-410, and cam and heads should be 410+(usually around 430 depending on cam and head choice.
Old 11-07-2010, 01:22 AM
LS 69 camaro's Avatar
sounds good guys.i live in montana and do not have no smog problems.i have a stock lq4 out of a 2001 truck.i have long tube headers on it in my 69 camaro but i would like to add some other small things to try to make close to 400 crank hp any help would be great.
Old 11-07-2010, 01:50 AM
you can make 400 flywheel with an under drive pulley, good exhaust, ls6 intake, ported tb, and lt's, but if you want to make sure, add a small cam, like a gt2-2, idles like stock, will make about 380 to the rear tires and waaaay over 400 at the crank.
Old 11-07-2010, 01:32 AM
BlueMagicSS's Avatar
If I remember correctly I've seen people running a 383 stroker with a small (224ish druation) cam with a good tune, but I'm not sure how much HP they were making to the wheels. You would have to run shorty headers and some smog legal heads. You could run a P1 charger with certain mods and still be smog legal. The main thing will be the cam and the bottom end that the tech really won't be able to tell by looking at the engine if it's CARB approved or not.
Matt
CA Licensed Smog Tech
Quick Reply: 450hp+ Smog-legal engine combos
