Replacing stk head haskets on stk heads, any difference between the 97-01 and 02's?
The reason I ask is this. I'm about to do a cam swap, but at the same time I'm pulling the heads and replacing a few bent valves. I've found that compressed gasket thickness on the 97-01 gaskets is 0.056", and the 02's is 0.060". What, if any, will the compression difference be? Will the 02' gaskets cause for slightly lower compression, or am I thiking about that backwards?
Also, the 97-01 gaskets are made of a composite material, whereas the 02's are a steel shim style gasket. Are there any benefits to one or the other?
Thanks for any help guys.
TT-TECH Veteran
Look on SDPC website they have a write up about this exact question. They tell you witch head gaskets will work for different years and the 02-03 gaskets will not work on the earlier models. one of the coolant passages around the number 6 and number 5 pistons will cause it to leak coolant depending on the year of the head. There is a small half moon shaped indention on some heads that will leak if you use the wrong gasket just a heads up. As far as the compression you will not know the difference in power that is messurable.
